Need some help with my nuts.
AntD
Post by AntD » Tue Feb 04, 2014 3:25 pm
So.. The SJ came with the spare, and the mount... But no nuts for the wheel once on the mount - So currently cruising with a big black mount sticking out and no spare on it!
Being a simpleton I thought it would be easy, measure the diameter (11 mill) and get nuts - though I've been reliably informed there are different thread types?
So.. I need 3 nuts - But which 3? From where?
And... What's the best way to secure the wheel - padlock through the lock hole?
Re: Need some help with my nuts.
Post by ScottieJ » Tue Feb 04, 2014 3:27 pm
Should just be wheel nuts so M12x1.25
I have loads of spares if you want a few?
AntD
Post by AntD » Tue Feb 04, 2014 3:37 pm
Excellent, thanks for that.
Won't postage be as much/more than I can buy them for?
AntD
Post by AntD » Tue Feb 04, 2014 3:40 pm
In fact we're not quite there, they're not wheel nuts - bolts are part of mount so they're everyday normal nuts, to go on bolts not in holes!
Post by dan_2k_uk » Tue Feb 04, 2014 3:52 pm
I'm pretty sure they are wheel nuts. Try a wheel but on it and see.
Post by ScottieJ » Tue Feb 04, 2014 3:53 pm
AntD wrote:In fact we're not quite there, they're not wheel nuts - bolts are part of mount so they're everyday normal nuts, to go on bolts not in holes!
It it's an original spare wheel mount it will use standard wheel nuts, Sjs use wheel nuts not bolts ;) take one off one of your wheels and try, I won't want anything for a few nuts, just cover postage :thumbup:
AntD
Post by AntD » Tue Feb 04, 2014 4:00 pm
There's definitely three bolts sticking out of the mount, welded in. No holes for wheel nuts. Maybe it's not a standard mount...?
AntD
Post by AntD » Tue Feb 04, 2014 4:02 pm
I'll upload a photo when I get home.
Post by ROBBIE » Tue Feb 04, 2014 4:06 pm
Sounds standard three bolts 2 at top 1 at bottom, wheel nuts fit
Post by ScottieJ » Tue Feb 04, 2014 4:51 pm
Just to clarify this is a wheel nut, 19mm with an m12x1.25 thread
and it fits on a suzuki hub and spare wheel mount
