what happened here?
kiwizook
what happened here?
Post by kiwizook » Thu Feb 06, 2014 6:37 am
I sprayed the inside of my bonnet with 1k primer, and this happened in just one spot. anyone know what caused it? almost looks like it didn't stick on properly
Re: what happened here?
Post by dan_2k_uk » Thu Feb 06, 2014 6:52 am
Guess there might have been some sort of oil/fluid there that its reacted with or just sat on top of.
Post by ROBBIE » Thu Feb 06, 2014 6:53 am
looks like could have been damp or dirty
Post by Jordi » Thu Feb 06, 2014 11:05 am
Either damp or oil on the panel.
You can get special solvent panel prep cleaner. Probably find the whole thing needs flatting off and priming again
kiwizook
Post by kiwizook » Thu Feb 06, 2014 6:31 pm
I was thinking of just sanding back the affected areas, and then repaint those area's. funny thing is I wiped it down with thinners, so wouldn't expect anything like this
timwilks13
SCUK Website Padawan
Post by timwilks13 » Thu Feb 06, 2014 6:34 pm
Dude when i painted my windscreen, someone had previously painted the windscreen in a different colour. I sanded the old paint to rough it up, and cleaned it with white spirit, yet my paint reacted with the old paint and turned out just like yours has. Must have been an oil based paint or something not removed by thinners. I would sand/grind right back to metal and prime first then paint.
Post by donkeychomp » Thu Feb 06, 2014 10:04 pm
Orange peel like that can happen for all the above reasons. It can also happen if you lay the paint on too thickly or if it's cold and damp.
Post by Jordi » Thu Feb 06, 2014 10:16 pm
donkeychomp wrote:Orange peel like that can happen for all the above reasons. It can also happen if you lay the paint on too thickly or if it's cold and damp.
Also happens if your cak handed with a spray gun.
Post by donkeychomp » Thu Feb 06, 2014 11:33 pm
...that too. :hahaha:
kiwizook
Post by kiwizook » Fri Feb 07, 2014 4:26 am
Jordi wrote:Also happens if your cak handed with a spray gun.
:oops: :oops:
I'll sand it back, and try again. I don't think it reacted with the paint, as the layer underneath it is the original factory paint, and this was the only spot it did this
