Hello - Samurai bodywork and respray sought!
boxman
Post by boxman » Fri Feb 07, 2014 11:26 pm
Hi, I'm new to this site, I've had a Suzuki Sammy LWB for a few years.
It has a good Vitara 1600 engine [45,000 or so on the clock ] with plenty of life in it and it runs very well, but the bodywork is ailing a bit - gone downhill a little from these pics taken a couple of years ago, but still basically sound. I love it and I'm keen to keep it on the road and am looking for someone to do a bit of serious bodywork and a complete re-spray.
If anyone can point me in the right direction I would very much appreciate it. I'm in Shropshire, UK.
Thanks in advance.
Andy Crawford.
muddymesser
Re: Hello - Samurai bodywork and respray sought!
Post by muddymesser » Sat Feb 08, 2014 1:26 pm
welcome to the nut house ;) on here i think most people so all the body work themselves
looks like a pretty tidy lwb . . . if you put some pics of its current condition someone could point you in the right way
boxman
Post by boxman » Sun Feb 09, 2014 10:56 am
Hi, muddymesser - thanks for your answer. I guessed most would be DIYers on this forum - but maybe posting this will point to someone in the midlands area who'd be prepared to take this on.
Rust mainly fronts of wheel arches, sills, all the usual places. And a lot of unseen too, all of which I'm keen to get sorted.
Anyone?
Thanks.
Post by dan_2k_uk » Sun Feb 09, 2014 11:21 am
Hi and welcome.
I would guess that under the plastic sill trims there will be plenty more.
Almost everyone on here have repaired at least some of the areas you are looking at.
Have you considered getting a cheap welder and having a go yourself? I learnt to weld by sorting my bodywork out.
Not many have sprayed on here. Most just brush or roller on a decent self leveling paint.
Post by donkeychomp » Sun Feb 09, 2014 9:46 pm
Pity you are so far away, I'd do it.
boxman
Post by boxman » Mon Feb 10, 2014 3:02 pm
Hi, thanks for your responses. Yes, there is certainly a lot more unseen - I considered trying to do it myself, but I'm really looking for someone to take it all apart, do the necessary, and put it all back together again!
I will keep looking, and try to stop the rot getting any worse in the meantime.
Post by twiss » Tue Feb 11, 2014 3:42 pm
I second the idea to get yourself a welder and teach yourself!
I've spent a fortune on getting welding done in that past, but once you can take it on yourself £300 worth of welding turns into £20 of metal, £5 of gas and £2 of wire
Well worth it!
evans797
Post by evans797 » Tue Feb 25, 2014 1:14 pm
Hi, I also have a LWB but in a much more shocking condition. I'm using a local back street garage who do a lot of work with old vw campers so are used to buckets of rust. I'm sure you'll have someone similar near to you. Getting my to good running order at the moment then off to body shop so I can't advise on costs yet, but can keep in touch.
It's rust Jim, but not as we know it..
