Hello - Samurai bodywork and respray sought!
Posted: Fri Feb 07, 2014 11:26 pm
by boxman
Hi, I'm new to this site, I've had a Suzuki Sammy LWB for a few years.
- DSC_2852.jpg (152.96 KiB) Viewed 6904 times
- DSC_2869.jpg (203.01 KiB) Viewed 6904 times
It has a good Vitara 1600 engine [45,000 or so on the clock ] with plenty of life in it and it runs very well, but the bodywork is ailing a bit - gone downhill a little from these pics taken a couple of years ago, but still basically sound. I love it and I'm keen to keep it on the road and am looking for someone to do a bit of serious bodywork and a complete re-spray.
If anyone can point me in the right direction I would very much appreciate it. I'm in Shropshire, UK.
Thanks in advance.
Andy Crawford.
Re: Hello - Samurai bodywork and respray sought!
Posted: Sat Feb 08, 2014 1:26 pm
by muddymesser
welcome to the nut house
on here i think most people so all the body work themselves
looks like a pretty tidy lwb . . . if you put some pics of its current condition someone could point you in the right way
Posted: Sun Feb 09, 2014 10:56 am
by boxman
Hi, muddymesser - thanks for your answer. I guessed most would be DIYers on this forum - but maybe posting this will point to someone in the midlands area who'd be prepared to take this on.
Rust mainly fronts of wheel arches, sills, all the usual places. And a lot of unseen too, all of which I'm keen to get sorted.
- IMAG1855.jpg (143.22 KiB) Viewed 6861 times
- IMAG1857.jpg (97.67 KiB) Viewed 6861 times
- IMAG1860.jpg (132.02 KiB) Viewed 6861 times
- IMAG1861.jpg (141.26 KiB) Viewed 6861 times
Anyone?
Thanks.
Posted: Sun Feb 09, 2014 11:21 am
by dan_2k_uk
Hi and welcome.
I would guess that under the plastic sill trims there will be plenty more.
Almost everyone on here have repaired at least some of the areas you are looking at.
Have you considered getting a cheap welder and having a go yourself? I learnt to weld by sorting my bodywork out.
Not many have sprayed on here. Most just brush or roller on a decent self leveling paint.
Posted: Sun Feb 09, 2014 9:46 pm
by donkeychomp
Pity you are so far away, I'd do it.
Posted: Mon Feb 10, 2014 3:02 pm
by boxman
Hi, thanks for your responses. Yes, there is certainly a lot more unseen - I considered trying to do it myself, but I'm really looking for someone to take it all apart, do the necessary, and put it all back together again!
I will keep looking, and try to stop the rot getting any worse in the meantime.
Posted: Tue Feb 11, 2014 3:42 pm
I second the idea to get yourself a welder and teach yourself!
I've spent a fortune on getting welding done in that past, but once you can take it on yourself £300 worth of welding turns into £20 of metal, £5 of gas and £2 of wire
Well worth it!
Posted: Tue Feb 25, 2014 1:14 pm
by evans797
Hi, I also have a LWB but in a much more shocking condition. I'm using a local back street garage who do a lot of work with old vw campers so are used to buckets of rust. I'm sure you'll have someone similar near to you. Getting my to good running order at the moment then off to body shop so I can't advise on costs yet, but can keep in touch.
