410 smoking after oil change?
Sj410red
Post by Sj410red » Wed Feb 12, 2014 11:34 pm
After an oil change using the correct 10/40 oil she smokes upon start up, valve stem seals I hear you all say, so my question is how easy are they done on the 410 without removing the head?
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Diff & Box high breather pipes
Front Diff guard
timwilks13
SCUK Website Padawan
Re: 410 smoking after oil change?
Post by timwilks13 » Wed Feb 12, 2014 11:46 pm
you didnt use any engine flush before the oil change did you?
Post by andyrew » Wed Feb 12, 2014 11:49 pm
Mineral oil or synthetic?
Post by donkeychomp » Wed Feb 12, 2014 11:53 pm
Did you change the oil filter too?
Post by ScottieJ » Thu Feb 13, 2014 9:13 am
I presume you used semi-synthetic?
this often happens on old engines that have always been filled with mineral oil all their life.
It is possible to do the valve stem oil seals without removing the head but it can be awkward when refitting the collets as they are a non interference engine so you can't cheat and use the piston to hold the valves up.
Sj410red
Post by Sj410red » Thu Feb 13, 2014 9:31 am
No I didn't use engine flush, why should I of? And it's semi synthetic I used and a new oil filter was fitted to
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Jay18
Post by Jay18 » Thu Feb 13, 2014 10:13 am
I've noticed mine smokes a lot on start up and I use semi-synthetic, I haven't used engine flush either...
I've got the whole engine gasket set to do on my 410..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
dazerede
Post by dazerede » Thu Feb 13, 2014 10:24 am
My Sj smokes a bit but only on start up once it has been warned up and driven a few miles it clears up
4” calmini lift kit :)
timwilks13
Post by timwilks13 » Thu Feb 13, 2014 10:33 am
I only wondered if you had as with a lot of old engines general oil gunk can plug the tiny holes/gaps/cracks etc and using engine flush cleans all them out and can show you oil leaks that were previously sealed, which might have been one reason for the smoking, but you didnt which is good.
Post by ScottieJ » Thu Feb 13, 2014 10:47 am
timwilks13 wrote:I only wondered if you had as with a lot of old engines general oil gunk can plug the tiny holes/gaps/cracks etc and using engine flush cleans all them out and can show you oil leaks that were previously sealed, which might have been one reason for the smoking, but you didnt which is good.
Same thing can happen switching to semi-synthetic in an engine that has always used mineral oil.
