can anyone help me, looking for two door cards for suksuki sj413 1986
cant seem to get anywhere. thanks
door cards
Re: door cards
If its not a standard restored job just make some out of some thin aluminium sheet.
- donkeychomp
Re: door cards
i live in spain and the mot center wont test it, now it has to be too factory settings totally what a pain, i have just had to take all the aluminum treadplates from doors sills and bonnet also had to remove bullbar to get it tested, may have to custom make door cards out of plywood and spray matt grey, thanks anyway
- Cyprus Geoff
- Can I have a tow
Re: door cards
Bet they would test it if a local guy pitched up with it for MOT?
Re: door cards
Make them out of fibreboard or something like that, then cover them with vinyl fabric. If they look like they could be factory, then he should be ok with it. Otherwise, ring around the garages local to you, explain the situation (my truck is standard except for the stupid door cards) and maybe you'll find an MOT man who isn't so stupidly petty.
- muddymesser
Re: door cards
It's not to hard to make a set
- Screenshot_2015-01-17-20-19-55.png (294.19 KiB) Viewed 6319 times
- Screenshot_2015-01-17-20-19-38.png (355.81 KiB) Viewed 6319 times
