O2 sensor wires
O2 sensor wires
Hello all. - I need help in identifying the harness wires to the o2 sendor on my 97 vitara jlx
Fuel odour
Also, - there is a strong odor of fuel at the back of my car. - I have changed the fuel tank, the h oses, and the tank cover. - there are no leaks but the odour remains strong and this only happens when the engine is off. - any ideas??
Re: O2 sensor wires
When you changed the hoses, did you also check the tank vent hose?
Re: O2 sensor wires
Anton, bcause the car was poorly converted from a carburettor to a EFI engine there is no EVAP canister so the vent host from the tank goes nowhere but this odor problem only recently started after months of driving, I suspect the o2 sensor may be sending a wrong signal to the ECU so I need to know the colour of the harness wires that connect to the o2. - let me say also that I am having a hard start problem hot or cold, but once its started it runs flawlessly.
Re: O2 sensor wires
EFI stuff is above my paygrade, but ScottieJ or Darrel might know.
Re: O2 sensor wires
Thanks anyway for your interest in helping. Hopefully those guys may see this SOS and sail to the rescue. - cheers.
