Which zener diode
Which zener diode
Post by Anton » Thu Mar 22, 2018 9:49 pm
Hey, ppls. A friend of mine wants to put a pair of relays into his Toyota to switch his high power headlights. Recently the current draw (2x 60w bulbs, so 10a total load) melted the switch inside the indicator stalk, after which no headlights (although thankfully no fire).
I'm thinking a zenier diode would be good, to stop high currents flowing back through the circuit and maybe even into his ECU, but what voltage? Would 15v be ok, or should I go for 17v? I remember reading somewhere that +3v is a good rule of thumb, meaning that a 17 would be more appropriate, but my memory might be shonky. Or shcottky... :brows:
Robert.m
Re: Which zener diode
Post by Robert.m » Sun Mar 25, 2018 9:02 pm
I thought wiring the HP lights through a relay would be sufficient to avoid melting anything.
Post by Anton » Mon Mar 26, 2018 12:29 am
It is. I'm not worried about the lights melting anything once the relays are in, I'm worried about the voltage spikes that relays cause when their electromagnetic field collapses.
