As per the title, the drive shaft rotates even when I neutral, I only noticed it because I have a funny knocking noise coming from below and can't work out what it is (don't think it's the release bearing).
Is it normal for the drive shaft to spin even out of gear? It stops if you grab it but takes a fair bit of force to stop it.
Drive shaft turns in neutral
- timwilks13
- SCUK Website Padawan
Re: Drive shaft turns in neutral
Which shaft?
G/box to t/box?
T/box to axle?
Surely if they were moving the SJ would be moving?
I’m gonna say it’s not normal. In neutral nothing visible underneath should spin, other wise you would be moving.
If there is no resistance the intermediate shaft may spin, if the t/box was in neutral or had no output shafts fitted.
Not sure how it works but because the gearbox input is always spinning some of that energy is transferred by magic to the output, it will spin if resistance is low enough.
G/box to t/box?
T/box to axle?
The output shaft has gears around it on bearings, none of which are connected directly to the output shaft (they just "float" on the output shaft) and they're all meshed to the input shaft gears, so if the input shaft is spinning, the gears that "float" around the output shaft will also be spinning (at different speeds). When you select a gear, a fork pushes one of the synchros into the gear, which forces the output shaft to spin at the speed of that particular gear. The rest are still spinning at whatever speed they want, they're just not connected to anything.
In neutral, the output shaft will have a tiny amount of power going through it - it'll want to spin at the average of gears 1-5, minus reverse. Basically the drag of the bearings transfers a *tiny* amount of power.
If the t-case is in neutral the gearbox has nothing to stop the output shaft from spinning with the tiny amount of power getting to it through the drag caused by the bearings.
- mike harris
- SCUK is my life
Yeh mine does this too
- timwilks13
Thats all I needed to know thanks guys! Yes the tbox was in neutral so I know realise with no resistance the output shaft will get residual energy from the input shaft.
The funny knocking noise I had was a bent heatshield from when I removed the gearbox fowling on the silencer. All is well and good!
Bent heatshield or you forgot to re fit all the bolts back for it?timwilks13 wrote: ↑Tue Mar 12, 2019 2:42 pmThats all I needed to know thanks guys! Yes the tbox was in neutral so I know realise with no resistance the output shaft will get residual energy from the input shaft.
- timwilks13
No its was bent, hadn't removed it and the exhaust had bent it backwards.
