Wiring diagrams
Re: Wiring diagrams
hi i've got a 1988 suzuki sj410 santana my hazards lights work but not the indicator arm its self any ideas what it could be?
Re: Wiring diagrams
Hi Tommo
They have separate fuses for hazards / indicators so check that first.
Re: Wiring diagrams
hi guys im abit stuck my fuel gauge does not work but the is to cables a yellow and red and a violet and yellow one which cable does what? can someone help me
Re: Wiring diagrams
Yellow with red tracer goes to the fuel sender unit.
Not aware of any violet wires on an SJ
- kj.png (62.58 KiB) Viewed 44236 times
Re: Wiring diagrams
so it the Y/R the only cable that should be connected?
- ektoz
Re: Wiring diagrams
Thanks very much scottie !!
Re: Wiring diagrams
Anyone know how to change the fuse board out of a Suzuki sj Spanish model, to a fuse box out of a jap model, as I have snapped my fuse board an can't seem to find one anywhere
Re: Wiring diagrams
Just added the Spanish Santana Samurai wiring diagram to the first post.
Re: Wiring diagrams
Would anyone have a pinnouts diagram for these clocks?
- received_10154006088391849.jpeg (232.48 KiB) Viewed 42672 times
Re: Wiring diagrams
I've put this together for the type with the VSS, I believe earlier ones would still look the same.
- Sammy clocks 1992.jpg (434.68 KiB) Viewed 42661 times
