Post
by Anton » Fri Nov 21, 2014 4:26 pm
Kiwibrad wrote:Ha. Think I got a price of him a while back. His are probably a bit better as his shafts are bigger diameter.
Is there really any kind of load on them so that you need to worry about shaft diameter? £45 is "zook" money, £185 is... Not so much...
We're a bunch of broke blokes.
mattmiles
Post
by mattmiles » Sat Nov 22, 2014 11:22 am
Awesome build! Just wondering what you have made up for your top radiator hose?
I used to run a 1300 16v myself, and used a thermostat housing outlet from an LHD GTI (part was from the states)
Shame you weren’t happy with the Mazda cap, I moved my engine and box mount forwards, only around 15mm, which gave me the clearance needed.
Pics attached
- 2014-02-23 17.53.58.jpg (176.02 KiB) Viewed 8754 times
- 2013-04-23 11.41.13.jpg (149.53 KiB) Viewed 8754 times
Kiwibrad
Post
by Kiwibrad » Wed Nov 26, 2014 10:51 pm
Anton wrote:Kiwibrad wrote:Ha. Think I got a price of him a while back. His are probably a bit better as his shafts are bigger diameter.
I didn't really think there was any load on them so I wasn't to worried. I have so many bits and pieces to buy for it so I love it when there's cheap bits!
Kiwibrad
Post
by Kiwibrad » Wed Nov 26, 2014 11:12 pm
mattmiles wrote:Awesome build! Just wondering what you have made up for your top radiator hose?
Pics attached
Thanks man
I took my thermostat housing into my friendly local engineers and got them to cut, turn and weld it. It's left it quite small to get the hose on but I think it should be fine.
As for the dizzy cap I did look at moving engine forward but it still looked tight. Your engine looks like mk 2 or 3, mines a mk 1. I know the internals of the mk 2 dizzy's are a bit different so maybe the Mazda caps fit better? It certainly wasn't a great fit on mine
Kiwibrad
Post
by Kiwibrad » Wed Nov 26, 2014 11:22 pm
robwizard wrote:Amazing work! Excited to see how this progresses.
Thanks. I can't wait to have it finished but its taking ages!
Kiwibrad
Kiwibrad
Post
by Kiwibrad » Wed Apr 08, 2015 6:20 pm
One thing I've found and not sure if others out there with yj's have the same but there is huge movement in the spring hanger bushes, they are new bushes and bolts are only just nipped up but I was surprised how much movement was in the bushes. Is there a better brand bush to use? I've made the mounts to take Suzuki bushes. Maybe that's the problem?
gp7186
Post
by gp7186 » Wed Apr 08, 2015 6:53 pm
ermmm!!! They look very familiar to my design if im not mistaken. Nicely done
- IMG_2015040818447.jpg (47.58 KiB) Viewed 8568 times
Kiwibrad
Post
by Kiwibrad » Wed Apr 08, 2015 7:13 pm
gp7186 wrote:ermmm!!! They look very familiar to my design if im not mistaken. Nicely done
Yes. Guilty! I looked at a few different conversions and really liked your design on the front and particularly like how it can all unbolt.
Kiwibrad
