clunk sound
Re: clunk sound
Get a compression test done i think might indicate if the rings are going.. Is it a constant stream of blue smoke or a putt putt putt.. constant stream i would think is the rings, but a putt putt could be one of the inlet valve stems leaking as Dan said. I have leaky valve stem seals on 1 cylinder, but it only smokes for about 20 seconds after i start it then its ok and hardly uses any oil.
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: clunk sound
The head is off my sj i have changed the oil valve seals reseted the valves.
Should i do the rings?
Re: clunk sound
Are all sj410 engines the same
