Mikes lwb build and repairs !
Re: Mikes kjahybrid challenge truck updated 27/08/2015
Post by mike harris » Thu Aug 27, 2015 7:12 am
Long drive this Saturday afertoon to go see Mr Richard, he's going to cage it over the coming weeks, can't wait !
Then when it comes back il be on a mission to sort out the bodywork and painting it before assemmbly resumes !
Mike :)
Post by mike harris » Thu Aug 27, 2015 7:16 am
I've used some flat headed alen key bolts m10 to secure the bed down with, they look Alrite I recon
Post by dan_2k_uk » Thu Aug 27, 2015 10:08 am
It's looking good Mike.
Guess it will come together pretty quickly once you have it back with the tubework done.
Post by mike harris » Thu Aug 27, 2015 3:12 pm
Thanks mate !
I've looked around it and there's a fair bit to do before its painted.
Need to make things a bit neater in places and stuff. Sure il get it done :)
Re: Mikes kja hybrid challenge truck updated 27/08/2015
Post by mike harris » Thu Aug 27, 2015 9:59 pm
I've got one or two issues il need to over come soon,
Rear bed can't come of when cage is on, so need to make the hole in the bed big enough to pull a whole winch through.
Next up is painting, where the cage will be I can't paint behind !!
Rear prop is also an issue as I think Bailey Morris won't want to lengthen the prop, only shorten another one !
Front Shock towers, rear shock mounts, front and rear bump stops, exhaust, fuel lines, brake lines, mounting the seats will be a mission in it's self ! All got to be made.
Needs a new bonnet, front ends bent, engine needs work !
Never ending list !
Ju
Post by Ju » Fri Aug 28, 2015 7:02 pm
It is coming along well and starting to look like it will be awesome when finished
Post by mike harris » Mon Aug 31, 2015 8:40 am
Thanks mate
Took it to Richard yesterday in scunthrhrope !!
Bloody long way that was, can't wait for him to cage it :)
Post by mike harris » Mon Aug 31, 2015 8:41 am
rundo
Post by rundo » Wed Sep 02, 2015 7:03 am
Whats up with rear locking hubs? Probably stupid question but I was thinking many times it would be great to have locking hubs on rear so you can unlock it and drive with front wheels only when needed. Anyone ever try that?
I know that rear driveshaft disconnect device exists, just wandering..?
Post by mike harris » Thu Sep 03, 2015 6:43 am
It has a fully floating back axle, which uses front hubs on the rear.
I put free wheeling hubs on so if I break anything I can switch the axle of and be recovered without doing further damage to components.
But yeh could drive it in front wheel drive, one wheel drive or select any given wheel to drive at it has lockers.
