Hallo guys!
Re: Hallo guys!
Re: Hallo guys!
The easiest way is to just use a 1.3 gearbox. It's a lot of work to fit the vitara gearbox and no cheaper because you need to convert the output of the gearbox to bolt up to the transfer box with a shortened propshaft. As Robbie says the transmission tunnel does also need a few tweaks but it won't be as extensive as mine unless you choose to spend a lot of money on a twin transfer box set up.
Re: Hallo guys!
Thanks a lot!
Ok! I get it!
Engine swap will be my last work. At the time i almost finished with electric problems and i started bodywork.
Ok! I get it!
Re: Hallo guys!
Hi and welcome.
Just try it with the 410 engine and enjoy it. As long as your tyres aren't too big you can go have some fun.
Re: Hallo guys!
Dan that i 'm going to do until to finish suspension and body works!
Re: Hallo guys!
Pix of the wee beastie! We need pictures!
Re: Hallo guys!
This is from my first ride at the mountains
- image-9f723adec7b0978ac1d2c74834e2241b5697c69cc01a065f7d835a6009b29223-V.jpg (237.3 KiB) Viewed 6255 times
- 20151226_162717.jpg (581.01 KiB) Viewed 6255 times
Re: Hallo guys!
- Tramp
Re: Hallo guys!
Great photo - living the dream!
