Stripped threads on wheel studs
Eltoon
Post by Eltoon » Thu Apr 28, 2016 11:19 am
Hi. Any thoughts chaps? Took my SJ413 to a garage today to get the front wheels balanced but the mechanic found that at least 2 studs on one side had been cross threaded so are fooked :bawling: . Any recommended options here? Are the studs replaceable or is it a case of the whole hub having to be replaced? Or would a tap and die set be an option for a hopefully simple repair?
Jazza
Re: Stripped threads on wheel studs
Post by Jazza » Thu Apr 28, 2016 12:29 pm
I wouldn't be too keen on trying to tap them if there is not much left, as it is what holds your wheel on after all!
As far as I am aware all of the wheel studs are replaceable. I am pretty sure that the stud size you are looking for is M12x1.25 34mm
Here is a link to someone that is selling some OEM ones on ebay:
http://www.ebay.co.uk/itm/WHEEL-STUD-BO ... Sw37tV~bCM
I far as I am aware the studs on a SJ413 are the same as the Samurai (Someone please correct me if I am wrong).
Regards, Jay
Post by ScottieJ » Thu Apr 28, 2016 12:35 pm
I have studs and nuts spare. could sell you a few
Eltoon
Post by Eltoon » Thu Apr 28, 2016 1:43 pm
If you could sell me a few that would be great Scottie! Happy to pay for express post too if you're ok to post to sunny (cloudy today actually) Spain.
Eltoon
Post by Eltoon » Thu Apr 28, 2016 3:02 pm
Anyone changed the wheel studs? Just want to know if there's an easy way or if the entire hub has to come off.....? Looked on trusty old youtube and a lot of the time it's pretty easy(ish) but I don't know if it will be on the Suzuki.
Post by ScottieJ » Thu Apr 28, 2016 3:35 pm
Should be able to change them just by removing the caliper and brake disc.
I'll dig some out tonight for you.
Eltoon
Post by Eltoon » Thu Apr 28, 2016 3:54 pm
Nice one!
