What Did You Do To Your SJ Today?
Re: What Did You Do To Your SJ Today?
Yeah I'm still alive
. Just haven't really bothered with the SJ recently, but I'm going to get back on it now. New front tyres is first thing on the list.
- Winching along now
You have a Suzuki digital clock with an LCD that still works?
I bought 2 off eBay, had them all apart but couldn't get the displays to work
Prepping mine for 2 days now took a while to sand and fill the thing ready for its new paint job n its still not perfect not bad for whats its for though
- image.png (561.47 KiB) Viewed 11995 times
Yeah working clocks are extremely hard to find. The screen was so faded on my first one, it was just a blank orange rectangle. Then armed with some dodgy internet info on how to fix the display, I tried to fix it with a heat gun. Needless to say it ended up in the bin.SherwoodNash wrote:You have a Suzuki digital clock with an LCD that still works?![]()
Just pot luck I managed to get a perfect one off eBay.
Me too x 2ferris wrote:Needless to say it ended up in the bin.
Had a day off, so just tinkered...........
........ fitted a Clicky Starter Kit, which I realised after ordering. I probably won't get any benefit from
Thanks to Darrell, I found out that the 410 already has a direct 12v supply for starting fitted as standard!
.........fitted a new Seger Low tone horn in addition to the factory High, so have dual note now.
.........fitted a beefier, dizzy to firewall negative cable for better ground.
Fitted another starter and alternator this evening after my starter shat itself and well my old alternator was in its last legs.....I can now have wipers, heaters and my headlights on without the voltage dropping
and another bonus is my stereo doesn't cut out at high volumes anymore
I spent yesterday trying to figure out the best way of wiring my manifold sensors to my microsquirt... TPS, CLT, injectors... done
Currently in between moving house and lodging in a farm house without decent tools, so just doing naff tinkering jobs
Needing a matching switch for front fog lights I found a 'Carry' one. Hairdryered off the decal, trimmed corners and reversed back on.
Then just drilled small indents for paint.
