Will a 410 grill fit 413
SherwoodNash
Re: Will a 410 grill fit 413
Post by SherwoodNash » Sun Aug 21, 2016 9:13 pm
Nice clean look Andy.
If you're like handy Andy, you could also make a centre section out of perspex like this ready made one on the 'bay.
http://www.ebay.com/itm/201277461796
Listing blurb:
Everybody wants the old style SJ410 grille on their Samurai. It gives your little rig that big rig anus / Hummer look.
Problem is, you can't buy them new, it's hard to find them in a boneyard, and even if you got your hands on one it requires extensive cutting and grinding of your sheetmetal to make it fit.
Well, now there is no reason everybody can't have this cool looking grille style! This product is basically a new center section for your current Samurai grille. Yes, some cutting of your grille is required, but this is plastic and cuts easy. Simply remove your current center section, screw in this replacement ABS panel, paint it and you have that unique style to your front end.
Comes with center section, mounting screws and complete instructions. Total installation time is under an hour using basic hand tools.
Last edited by SherwoodNash on Mon Aug 22, 2016 12:01 am, edited 2 times in total.
SherwoodNash
Post by SherwoodNash » Sun Aug 21, 2016 9:30 pm
If money's no object........
http://www.lowrangeoffroad.com/samurai- ... ement.html
Blurb:
Most like the look of the older SJ410 grill and it will fit your Samurai by replacing your grill. With a little work this gives a great look to you machine! Comes primed and ready to paint.
Note: This is not a direct bolt-in-place part as the factory one is generally spot welded in place on the top.
You will need to custom mount it if you plan on mounting onto your Samurai.
You will need to cut the headlight buckets from the Samurai Grill.
SlimGrim
Post by SlimGrim » Sun Aug 21, 2016 11:03 pm
That's not a bad shout actually!
___________________
Post by ScottieJ » Mon Aug 22, 2016 9:17 am
It is a bit of a bastard of a job usually, the screws holding the 413/samurai front panel on rarely come out without a fight, some of them you can't get to with a hammer and chisel to persuade out and then once you have got it off you do need to modify the light bowl sections a bit, well you do on samurai wings, 413 ones might be a bit easier.
I've just got a whole 410 front end to go on my Lwb
But finding one without rust is nearly impossible.
