the no dosh LJ revamp
Re: the no dosh LJ revamp
Post by donkeychomp » Fri Jul 21, 2017 9:13 pm
Made a start on the inside today, and the number plate light got done too, it was covered in tiny scratches but some fine wet and dry got that sorted. I will be making some panels for both sides and the floor, the roll hoop will probably have to come out to do it properly, might even get that blasted then powder coated.
Post by ROBBIE » Fri Jul 21, 2017 10:05 pm
Looking good as always
Post by donkeychomp » Fri Jul 28, 2017 12:10 am
Finished the other side in this so called 'summer' weather. Need to go get some MDF next. And the Pro Comps are all done ready to go on. Also ordered some new brake shoes for the next MOT, matey mentioned they were ok but not brilliant...and I need to do something about those holes!
Post by Anton » Mon Jul 31, 2017 1:37 pm
:doublethumbs:
Post by donkeychomp » Tue Aug 01, 2017 11:10 pm
Bit of routine door maintenance...
Post by donkeychomp » Thu Aug 03, 2017 9:32 pm
Still at it with this door, gave it a coat of primer to see if there were any imperfections. Short answer, yes. Loads of filler later and I'm stil not done!
SlimGrim
Post by SlimGrim » Thu Aug 03, 2017 11:20 pm
Yes dude this looks mint!
___________________
Post by donkeychomp » Fri Aug 04, 2017 12:06 am
Mint? Well it is a sort of mint green.... :hahaha:
Post by Jordi » Fri Aug 04, 2017 7:13 am
I prefer dents Alex.
Post by donkeychomp » Fri Aug 04, 2017 9:04 pm
I have a selection of hammers should you require extra dents...
