the no dosh LJ revamp
- donkeychomp
Re: the no dosh LJ revamp
MOT is friday. Did a check of everything and it all works as it should. Had an issue with a front side light, all fixed now with a bit of solder, plus I had it on upside down and it was dimmer than the other one! Only worry I have is the rear brakes but if that fails I have the shoes in the car and hopefully I can persuade them to fit them there and then.
- donkeychomp
She passed!
No mention of the brakes but an advisory on play in the front hubs...wondering if he means the wheel bearings? Never mind I have a year to get that sorted.
Got a mile away from the test centre and the fog light fell off! Repaired it and it's back on but I will get a new one.
- WP_20171103_001.jpg (111.78 KiB) Viewed 6577 times
- WP_20171103_002.jpg (111.27 KiB) Viewed 6577 times
- WP_20171103_014.jpg (110.07 KiB) Viewed 6577 times
- Winching along now
Awesome, glad to hear it passed!!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
- donkeychomp
Thanks lads. In 20+ years of owning Suzukis I have never had one fail an MOT. Maybe as I still go to the same place, and the tester loves the LJ...
- donkeychomp
Anton, long time no see hope everything is as ok as possible for you!
In hospital again, coming home tomorrow. Not having the most fun ever right now, but I should be ok.
- donkeychomp
Give me a call when you get home matey. Long time no see.
Will do!
