Hi,
I'm looking to find somewhere in the UK I can buy SJ410 King Pins, a set of Kin Pin Bearings (top and bottom) and a King Pin Shim Kit. I searched the forum, but the links I found were 10 years old and didn't seem to work for me.
While I'm asking, I also need a oil seal for the drivers side front drive shaft
If anyone knows and can reply with a link to a web store I'd be really grateful.
Cheers,
Al.
Where to buy SJ410 King Pins, King Pin Bearings and Shims UK
Re: Where to buy SJ410 King Pins, King Pin Bearings and Shims UK
hi on ebay you can get a full kit kingpin bearings/shims oil seals and swivel seals for both sides they are from japan my friend uses them all the times they are very safe about 2 weeks delivery i think about 60 to 80 pounds there are loads of different companyshope this helps tony in cyprus
Used these for a few bits in the past. UK based company.
https://www.jimnybits.com/sj-samurai/se ... parts.html
Anything they don’t have i’ve usually ordered from ebay or Low Range Off Road in America.
