Hi there. I was wondering if anyone knew of a common problem with grand vitara 11 plate Ddis washers.
None are working. We took the wheel arch out and put one of the pumps on a battery and it worked fine but none are working with the washer arm in the car. The wipes all work fine. I’ve looked at fuse box layouts but can’t see a separate fuse for the washer pumps.
Any tips. Then back washer hasn’t worked for ages but the front one has stopped too now.
Thanks in advance
Rol
Grand vitara 11 plate washers not working
