Coiled turqoise samurai 16v
- d_r_1989
- Winching along now
Re: Coiled turqoise samurai 16v
Once I have the front diff changed I'll be staying 4.3 and then sort the transfer box with some reduction gears. Im also considerkng rhe 26 spline front shafts so i cannuse 2 un modified rear diffs, ease of use. Follow your original advice scottie just 4 years later
- d_r_1989
So iv treat myself. Hopefully be back together by weekend and ready to go play!
- d_r_1989
Side by side comparison. The new shafts are a nice amount bigger, definitely softens the blow from the cost!
On the list
there a good bit bigger! Gonna be pretty unstoppable
- d_r_1989
So my speedo stopped working and I'm not totally certain. That the vss was working as its made hardly any difference to the performance.
I'm also wondering if its possible to change from some Spanish clocks to the jap clocks and just rewire it. The vitara speedo is so far out and lazy to respond. Tried to adjust using the little lever but made no difference really
