softer suspension
softer suspension
hi all
I would like to get my suspension a lot softer on my sj
How or what is the best way of doing it
Re: softer suspension
What suspension setup are you currently running?
all standard
I would go for some softer shocks then. Somehting like Procomp es1000?
will the Procomp es1000 help muchHenry wrote:I would go for some softer shocks then. Somehting like Procomp es1000?
where the best place to get some
seen some e3000 will they do??
- Edweird
I think the 3000s are harder, designed for use with lift kits I think.
I had ES3000s on mine... have taken them off because they are so hard!!!
If you're racing on loose surface I'd imagine they'd be alright...
...but they are rubbish for road use!!! SO BUMPY!
Bedford rascal rear springs and rear sj springs up front
the problem with SJs is that the springs are too short to give a good ride, use longer springs at each end and you improve articulation and comfort
will leave the e3000 aloneScottieJ wrote:Bedford rascal rear springs and rear sj springs up frontthe problem with SJs is that the springs are too short to give a good ride, use longer springs at each end and you improve articulation and comfort
Will have to look out for some Bedford rascal rear springs
coil conversion?
