Changing Timing Belt On SJ 413
Famerbennie
Post by Famerbennie » Sat Jun 04, 2011 2:14 pm
hi was just wondering what damage could be done it you don't put the timing belt on correctly. Ben
ack
Re: Changing Timing Belt On SJ 413
Post by ack » Sat Jun 04, 2011 7:52 pm
Generally speaking - if you have not put high performance flat pisons in, - nothing except it'll run badly.
read this post for info on the timing belt change procedure:
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =13&t=3202
Your 1.3 will have 4 bolts holding the accessory pulley in place.
Note especially the red-colored text.
I hope that this helps!
Post by twiss » Sat Jun 04, 2011 7:57 pm
Hey ack you are knowledgeable about engines... is the 8v sidekick/tracker 1600 engine an interference engine?
i.e. it will damage the engine
Post by ScottieJ » Sat Jun 04, 2011 9:15 pm
no its not twiss, its a non-interference motor :thumbup:
Post by twiss » Sun Jun 05, 2011 4:26 pm
Always handy! Snapped cambelt is a side of the road job rather than an engine rebuild ;)
Post by twiss » Mon Jun 06, 2011 5:26 pm
Non interference means that if the cambelt snaps... the pistons don't go up far enough to smash the valves...
So you just put a new cambelt on.
If it was an interference engine, the cambelt snaps... pistons bend valves = expensive
Post by twiss » Tue Jun 07, 2011 9:28 am
I haven't been to boxgrove... I've heard it's good though.
Where are you from Hugh? Close enough to go to boxgrove is pretty close!
Post by twiss » Fri Jun 10, 2011 6:49 pm
Ahhh thats cool, ... I'll pop by when I have my SJ back on the road ;)
Famerbennie
Post by Famerbennie » Fri Jun 17, 2011 7:32 pm
no worries have done the timing belt peace of cake and car runs fine
Post by ScottieJ » Fri Jun 17, 2011 8:07 pm
Famerbennie wrote:no worries have done the timing belt peace of cake and car runs fine
:good:
