doubts...
Re: doubts...
carnt sell mine couldnt stand the thought of some little oik having my fun
Re: doubts...
Just think... it could end up like one of those battered up SJs the chavs use/smash up at pay and play sites
THE HORROR
THE HORROR
- Lil_Beastie
Re: doubts...
twiss wrote:Just think... it could end up like one of those battered up SJs the chavs use/smash up at pay and play sites
THE HORROR
your not a chav!
Was:
Lil Beastie - 95 Sammie http://www.suzukiclubuk.co.uk/forum1/vi ... 22/t,3134/
Now:
Lil Monster - 86 VW Caddy http://rat-look.com/forum/viewtopic.php?f=10&t=8805
Now:
- turbo-tom
Re: doubts...
Lil_Beastie wrote:twiss wrote:Just think... it could end up like one of those battered up SJs the chavs use/smash up at pay and play sites
THE HORROR
your not a chav!
he might drive like one though
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: doubts...
hahaha
its ok to tow an sj to recover it when it's broken/shit tom
if your brakes weren't sticking and an engine lighter than the moon, it would have been much easier!
Besides, my truck has MOT... sometimes
Every broken bit of it has been broken while road legal!
- Russ24
- Can I have a tow
Re: doubts...
erm?Lil_Beastie wrote:By water getting in through the vent, what do you mean? Have you cleaned out the drainage pipes in the vent under the windscreen?
I think everyone has downers about whether or not to keep theyre SJ at some point (if not often).
ok. no idea what you speak of.
- Lil_Beastie
Re: doubts...
Russ24 wrote:erm?Lil_Beastie wrote:By water getting in through the vent, what do you mean? Have you cleaned out the drainage pipes in the vent under the windscreen?
Wheres the water leak from inside? behind the dash/heater somewhere?
Was:
Now:
Now:
- Russ24
- Can I have a tow
Re: doubts...
yeah water collecting in plastic pipes.Lil_Beastie wrote:Russ24 wrote:erm?Lil_Beastie wrote:By water getting in through the vent, what do you mean? Have you cleaned out the drainage pipes in the vent under the windscreen?
comes out at bottom of heating system
- Lil_Beastie
Re: doubts...
Right,
You know the grill below the windscreen on the bulk head. Under that is where the heater takes in the air from outside. However it also colects the rain water to stop it going into the system, like it currently is.
The water drains down either end of the plate you can see under the grill. It drains into the engine bay through some plastic pipe that you can see under the bonnet, stick out the bulk head. They will be full of mud.
Youll need hot water, and a thickish (1-2mm dia). Poke the wire round through the grill on top down into the drainage pipe. And up through the pipes coming going into the engine bay.
Keep pouring water into the grill and keep poking around.
Eventually it'll start working its way through.
Was:
Now:
Now:
- Russ24
- Can I have a tow
Re: doubts...
Lil_Beastie wrote:Right,
Keep pouring water into the grill and keep poking around.Eventually it'll start working its way through.
nice one.
having looked earlier i have seen the mud......
that will contribute to the water seapage..
HOWEVER i have found something more disturbing while looking for these blocked pipes.
corrosion and bubbled paint just below the windscreen below the rubber seal. real bad times. and poking that with wire would be a bad idea. just be where the rest of the water is getting in.
shit
thats quite abit more work.
