supermick83
Post
by supermick83 » Thu Jan 29, 2009 3:10 pm
Well guys just paid 250 euro for my sj410. Was workin on it all day and have it running now after changing oil, oil filter, plugs and put new battery in also
. Its cutting out if i turn choke off can anyone shed some light on this matter? Ps I'm a new member
Supermick The Man With the Big D***!
lordyharmerz
Post
by lordyharmerz » Thu Jan 29, 2009 4:59 pm
Mine does that, when we spent some time and adjusted it, found that she just stalled when driving, decided to let slide, set it back again, runs fine so long as i dont push choke all the way in. my freinds run 413's one has a nikki carb the other a webber, and we all suffer with idling problems if we fix the idle then they dont drive right. so we just leave it with a slightly higher tickover. dunno if its a common fault or we just arent as good as we think. dodgy things chokes are, my dad n grandad would always try to find an auto choke to replace the manual on any car they owned. dunno about technical terms but we took my rocker cover off and adjusted the slidey things inside so they wernt as loose, that helped the idle and rattling sound.
still cuts out though. hope thats a help but if its not, someone will put me right and tell you something usefull. haha.
supermick83
Post
by supermick83 » Thu Jan 29, 2009 5:29 pm
Thanks buddy i've ordered new distributor but will prob end up in same boat leaving choke on slighty!
liljitjit
Post
by liljitjit » Thu Jan 29, 2009 5:43 pm
welcome on board fella! were all big d@*ks in here
[/color]before you laugh at mine , take a look at your own![/color]
supermick83
Post
by supermick83 » Thu Jan 29, 2009 11:38 pm
thanks man i need windcreen too and to fix my frame around it it's in tatters!
4eye
- SCUK Addict
Post
by 4eye » Fri Jan 30, 2009 11:46 am
Welcome...!
defo sounds like a common fault...my 410 does the same...but with a added extra...the choke doesn't stay out...so i invested in a clothes peg... a simple but affective bodge!
my ride.........
lordyharmerz
Post
by lordyharmerz » Fri Jan 30, 2009 5:27 pm
Loving the clothes peg idea, could hang ur socks from it after the footwell fills with water.
4eye
- SCUK Addict
Post
by 4eye » Sun Feb 01, 2009 2:01 am
.........No need...i alway's keep a spare pair in the glove box.........!
got caught out on an outing...and for 3hrs all i wanted was a nice dry pair of tootsie warmers!
my ride.........
supermick83
Post
by supermick83 » Thu Feb 19, 2009 8:34 am
Thanks guys got idle sorted there a few days ago. All i did was replace distributor cap and adjust its angle by 2 or 3 Degrees and that sorted it! no more choke it doesn't even need it starting just pump accelerator pedal few times and vrooom!
