fitting some bull bars tommorow, not looked at the job yet, will i have to remove the front bumper? where / are there many bolts retaining, how do the side plastic end caps attach?
thanks in advance Matt
front bumper / bull bar fitment
- Tramp
Re: front bumper / bull bar fitment
removing the front bumper is easy, its just 2 bolts in each front wheel arch, on the 'ears' that stick out from the chassis,
when i fitted my bull bar, (it was a vitara one) i had to remove the bumper to attach the bull bar brackets, the L shaped ones that go from the chassis, to hang under the front bumper
i then had to refit the bumper before fitting the bull bars, because it wouldn't slip down the back with the bullbar in place
so:
-remove the front bumper
-fit the Lshaped brackets
-refit bumper
-fit bullbars
easy peasy, you don't need to remove the plastic end caps off the bumper, and you may need some bolts to hold it all together, i think i used x4 m8x120's for the chassis and x4 m10x50's to bolt the bull bar to the brackets, (if i remember right, you might be best measuring yourself!!!) I used zincplated bolts to stop them corroding, but they did any way,
Luke
p.s. to remove the plastic end caps, its just a few plastic 'push' clips, that can be easily prised out,
so:
-refit bumper
-fit bullbars
Luke
tramp my friend thats awesome mate, will tackle this tommorow then. this post was very informative cheers for the step by step too, i could just see me fitting the bull bars then wondering how do i get that bumper on lol. cheers mate
tramp, was exactly as you described mate, that was awesome info. cheers
- Tramp
no worries, glad you got it sorted,
i bet you will need advice on spot lights next
Luke
Luke
well actual;ly ...lol
