SJ410 engine swap.
Harker
SJ410 engine swap.
Post by Harker » Tue Jul 10, 2012 10:08 am
Hi every one. Common question asked on here I know but I was wondering what's the easyest engine swap I can give my 1986 SJ410. I'm not looking for immense speed although a little more then it's got would be nice. I use it for driving round feilds for shooting, but tracking between permissions can be a pain because it's just so slow.
Also what am I going to need? To convert from a 970cc to another engine. I.E gearbox, etc.
Huge thanks
Alex
Re: SJ410 engine swap.
Post by twiss » Tue Jul 10, 2012 11:09 am
Hi,
There aren't really any engines you can just drop into a 410. You can use a SJ413/Samurai gearbox and a 1.3 or a 1.6 engine, but you need to adjust the gearbox mounting crossmember to fit the different gearbox.
Once you have done that though, you can go for 1.3 8v (carb/injection), 1.3 twin cam (swift engine), 1.6 8v (carb/injection vitara engine) or 1.6 16v (vitara again)
I would say if you're gonna do it, might as well put a 1.6 engine in it straight away :)
Harker
Post by Harker » Tue Jul 10, 2012 12:26 pm
Thanks for the reply. So I'm guessing it's best to take the 1.6 engine, gearbox and clutch from the same vehicle? Sorry for the stupid question, this is the first time iv ever attempted somthing like this :)
Post by twiss » Tue Jul 10, 2012 1:32 pm
Well if you take the vit gearbox as well as the engine its a bit more complicated because it has the transfer box built in.
I personally would use a samurai gearbox and a vit 1.6 8v engine.
Good balance of easy/power :)
If you are interested in putting a vit gearbox in check out scott's build thread
http://forum.suzukiclubuk.co.uk/vi ... f,22/t,12/
Sorry but I cant remember what page the best pics of it are on
Post by ScottieJ » Wed Jul 11, 2012 12:17 pm
twiss wrote: but you need to adjust the gearbox mounting crossmember to fit the different gearbox.
Only if you have an early 410 with skinny props, the later ones gearbox crossmember is in the same position as 413s and Samurais
chrisj410
Post by chrisj410 » Wed Jul 11, 2012 7:49 pm
ScottieJ wrote: Only if you have an early 410 with skinny props, the later ones gearbox crossmember is in the same position as 413s and Samurais
This explains a lot :lol:
Harker
Post by Harker » Fri Jul 13, 2012 9:04 pm
Thanks for the reply guys, it's much appreciated.
Harker
Post by dan_2k_uk » Fri Jul 13, 2012 10:14 pm
Or if you currently only have a 4 speed box swap to a 5 speed for slightly better road use.
Dan
saull-hunt
Post by saull-hunt » Sun Nov 18, 2012 7:49 pm
can any one tell me what 1.6 or over diesal engines i can put in my suzuki sj4 10 without a great deal of modifications?? Also is it possible to change it from leaf springs to bigger shocks and springs??
Post by ScottieJ » Mon Nov 19, 2012 1:07 pm
The simple answer is no, it will need new engine mounts, a 413 gearbox, adapter plates (for diesel) and probably other custom bits made.
A 1.6 8v vit engine is the easiest but will still require a 413 gearbox, 413 flywheel, 413 clutch, custom engine mounts, possible a 413 sump and oil pick up pipe mod + maybe some other bits.
As for the suspension, converting to coil suspension is a conversion that needs to be done by a professional or experienced fabricator and will require an IVA test (£450 if you pass!) to be 100% road legal.
Easiest thing to do is to fit some lift springs and decent shocks www.llama4x4.co.uk
