Anyone ever fitted a SU hif44E carb to a SJ?
slaterfett
Post by slaterfett » Sat Sep 29, 2012 5:53 pm
Hi folks.
I've bought a SU HIFF44E off ebay and for the life of me I cannot get it to work.
It was off a Maestro which had done 40,000 miles.
This carb has a solenoid fitted to it which connects to the ignition, a fuel cut off I think.
Basically I've got fuel going to the carb but no fuel is reaching the inlet manifold. So no spark or engine start. I've fitted everything correctly.
Thanks in advance
I'm a stinking thief don't buy parts off me!
Re: Anyone ever fitted a SU hif44E carb to a SJ?
Post by Darrell » Sat Sep 29, 2012 7:14 pm
I believe the solenoid to be a fuel shut-off like you said, so I assume you have left this disconnected.
http://www.maestro.org.uk/forums/showthread.php?t=10360
chris71920
Post by chris71920 » Mon Oct 01, 2012 10:09 pm
Mines got an HIF44E and it works fine! I just left the solenoid as it is, unconnected. And hooked the lines up as with a standard HIF and off she went :)
Have you checked the float level and that the needle valve is letting fuel in?
Post by Edweird » Tue Jan 01, 2013 8:55 pm
You said there's no spark?
