any help? iv seen some EXTENDABLE LIFT & FLEX SHACKLES on e bay, is any1 running
these at minute? and are they realy cracked up 2 what they say? need to reduce
the size of the (fangs) at the front!! they give a approx lift of one inch, at the
moment im running a 2" lift with shackles. money is tight!!!!! oh their £105
or has any one local to me got a set up that will help for sale?
thanks
- jameswilts
Please help me find a new zook!!
Re: EXTENDABLE LIFT & FLEX SHACKLES
hi,, im running missing link/drop shackles,, they dont give any lift, but they give more articulation.. i think if your looking for more height, add a leaf is your cheapest bet. plus it seems extended shackles cause a lot off oversteer.
andy
andy
- jameswilts
quick pic!!
- 1.jpg (181.96 KiB) Viewed 7015 times
- jameswilts
yeh thats another option just need to bin these things their a pain
they just dig in all the time i just thought the flex ones would give a bit more clearance?
they probably won't help your problem TBH matey! i've got a load of old leaf springs lying around so perhaps we could make up a new pack for you with a bit more life in them than the ones you are running! then you could just go back to standard size shackles!
- jameswilts
sounds good to me mate!! i get the keys to the new workshop at the end of the month so will have to sort something out! cheers
No worries! i'll pick the springs up from my mates farm in chippenham next time i'm there for you!
