how to take the shafts out
- dazerede
Just a quick question on the axles I have got to take 1 of my backplates of on my rear axle I have undone the 4 bolts holding it on the casing how do I take out the shaft does it pull out or do I need to take the diff out
I looked in the haynes manual and it says it should pull out but I tried that gently as I don't want to buy any more stuff
4” calmini lift kit
4” calmini lift kit
Re: how to take the shafts out
Need a slide hammer or if its the knackered back plate hit it with a hammer
- turbo-tom
As Robbie says you need a slide hammer and some balls mate
Tom
Ford Fiesta ST
Ford Fiesta ST
- dazerede
Oh ok I just didn't want to hit it too hard incase I damage something
Chears guys
And also Chears for fast response that's why I love scuk
Chears guys
4” calmini lift kit
4” calmini lift kit
Late as usual. Slide hammer is easiest. Or bray shit out of the back plate with a BFH. When it comes out watch for the oil seal and any oil dribbling out.
I normally reverse the brake drum and bolt it back on then hit it with a hammer using a nice piece of wood to protect the drum always hit around the centre and from side to side
Gaz
Gaz
I use same method as Gaz as I dnt have a slide hammer
I bought a slide hammer. Made the job so much easier.
Hopefully i won't have this issue much longer. Once RW has his full float sorted. Saving for that one next. If i sell my 31s that should almost cover it.
- kibris
I used my hi lift jack makes a crackin slidehammer - bolt the base to the drum and wack away! job done
