2013 SCUK weekender 17-18th August @ Wagtail
- littlesammy
Re: 2013 SCUK weekender 17-18th August @ Wagtail
go on then ill have a go .
i take it its a weekend of mud mud and a bit more mud.?
i think i better get some different tyres hadn't i?
87 Samurai with added spice !
On page 19 a new member (steerwiththerear) asked to be on the list.
That would be the list full then.
Bring it on chaps!
Bring it on chaps!
Hurrah and stuff. Looking forward to this!
I may have to get one or two of you lot to help me get my CB working properly. I know nothing about RF equipment, even in theory. :-D
CBs are pretty much plug n play. Power, mic, aerial.Anton wrote:Hurrah and stuff. Looking forward to this!
There may be nothing wrong with my CB, but until I can test it with another CB owner, I dunno.
CB radios will usually just work if you plug them in, BUT they really should be set up properly with a SWR meter. They are pretty cheap to buy usually.Jordi wrote:Anton wrote:CBs are pretty much plug n play. Power, mic, aerial.
If you don't set the aerial correctly, and have a very good earth, this can result in the CB radio burning itself out.
I might have to fix my CB for wagtail
Twiss - I have an SWR meter, and from memory I'm getting a lot of reflected signal, but until I test it in an open area, there's no way to know if that's signal bouncing off houses, or off an incorrectly tuned aerial...
Can you put my mrs aka the monkey down for the last slot. So she can try out her new offroader.
- mike harris
- SCUK is my life
This will be really good lads !!
Dunk be good to see your suzuki, there's a wide variety of suzukis going to this. Will be. Site to see I am sure
