vitara 4u2 electricals
plugspanner
Post by plugspanner » Sun Aug 25, 2013 1:54 pm
i have a few questions i hope someone may be able to help.
i have just put the new fog light onto the rear tailgate as the old plastic bumpers have been removed and i have just positioned the wires from under the rear bumper to inside of the tail gate, now the light does not work, it did work before i removed the bumper and i am stumped.
are the switches a problem?
the other thing i have noticed is that when ever i use full beam or use the flash the central locking clicks, is this normal?
i am assuming this model should not have central locking and a previous owner fitted it as the wiring does not look factory done to me.
also is there a clear wiring diagram for this model all the ones i have seen are too hard to read.
thanks in anticipation.
shaun
Rhinoman
Re: vitara 4u2 electricals
Post by Rhinoman » Sun Aug 25, 2013 2:40 pm
It sounds like you may have an earthing problem.
coupedriver
Post by coupedriver » Sun Aug 25, 2013 2:43 pm
Can't help you much mate,I have a 1999 4u2 and its not got central locking,hope that helps
plugspanner
Post by plugspanner » Sun Aug 25, 2013 3:15 pm
thanks
i may just get rid of the central locking as it is not really needed and it may help
thanks
shaun
coupedriver
Post by coupedriver » Sun Aug 25, 2013 6:11 pm
If you do take it out and want to sell it,give me a shout,it bugs the hell out of me
Post by Darrell » Mon Aug 26, 2013 2:23 pm
Looks like the fog light is wired the same as the SJ.
Vitara foglight circuit.jpg (925.83 KiB) Viewed 8867 times
Red is live supply
Blue is switched live supply
Green is switched earth (only connected when the headlights are on)
Yes I believe the 4u2 didn't have central locking so without knowing how that's wired in I can't help, sorry.
plugspanner
Post by plugspanner » Mon Aug 26, 2013 2:28 pm
thanks
i will have another look at the wiring
it cant be too hard can it!
plugspanner
Post by plugspanner » Mon Aug 26, 2013 5:14 pm
still no joy with the fog light
does anyone know what colour wires that have going to their fog light, mine are green/black and green/blue.
i also seem to have 2 fog light switches?, i assume one was for the front fog lights? it has a large off button on it.
i have disconnected the central locking now the solenoid does not click every time i switch on/off the lights!
shaun
Rhinoman
Post by Rhinoman » Mon Aug 26, 2013 11:13 pm
Does it work with the headights on? I can't remember how mine works exactly but its a latching switch so it turns itself off when the ignition is off.
plugspanner
Post by plugspanner » Tue Aug 27, 2013 10:54 am
i have tried it with engine running and off, the odd thing is when i bought the anus the rhs fog light was hanging down under the bumper as it had had a rear ender but it still worked just dangling there, now all i have done is to relocate the wires into the rear tailgate and have a new light so it should have been a case of just connecting the spade terminals and it should have worked, the light and bulb work ok i have tried it.
it is baffling to say the least.
