rear brake pipe on disc conversion
hamer
Post by hamer » Mon Oct 07, 2013 9:36 pm
hi guys im trying to find a conector for the brake pipe hose to bolt upto
was hoping it would screw straight up to the thread that came out of the drum but its a difrent thread :(
im using female ended extended brake lines that came off a smurai
Re: rear brake pipe on disc conversion
Post by Anton » Tue Oct 08, 2013 4:33 pm
Do you mean that the brake pipe unions you took out of the drum don't fit the banjo style brake pipes?
Mine did! They're universal ones, I believe, and got a new set at my local motor factors for £1 each, re-flared the brake pipes and screwed them in - job jobbed.
Only replaced the old ones because someone had stripped the old ones of the first mm or so of thread - they still fit just fine.
If I were you, I'd take your flexies down to a local motor factors and get a brake pipe union for each side that mates up to the flexies, and just reflare your pipes to use the new unions.
hamer
Post by hamer » Tue Oct 08, 2013 5:34 pm
The thread inside the flexys doesnt look as deep as the fitting that came out of drum...ye mate wat you said thats the case lol
hamer
Post by hamer » Tue Oct 29, 2013 7:57 pm
bought some flexys off dave(llama)
all fitted but have no brakes iv blead them up all good but cant get them working tidy
it sort of brakes after a few pumps but then disapears again
its very scary lol
i have aisin samurai on rear and girlin samurai on front
had aisin calibres in the shed so used them,i also have 410 calibres but iv lost the sleaved bolts :(
would it be a case of bleading loads of fluid the the lines till they hold presure?
Post by ScottieJ » Tue Oct 29, 2013 8:14 pm
Is the bleed nipple at the top of the caliper when mounted? If not then there will be an air pocket above it. So you'll need to unbolt the caliper and rotate it so the nipple is at the top while bleeding it.
hamer
Post by hamer » Tue Oct 29, 2013 8:25 pm
ye it sits at top mate
Post by Anton » Tue Oct 29, 2013 10:27 pm
What angle do you have the rear Aisins mounted at?
And do they look like this:
hamer
Post by hamer » Tue Oct 29, 2013 10:54 pm
Hmm maybe im wrong and tgey not aisin calibres lol
Just looked and they say 3zm on them ?
And flexy goes in at bottom and bleed right at the top mate
Post by Anton » Tue Oct 29, 2013 10:59 pm
Something similar to that?
hamer
Post by hamer » Tue Oct 29, 2013 11:01 pm
ye thats it mate :)
