power steering
timwilks13
SCUK Website Padawan
power steering
Post by timwilks13 » Fri Nov 22, 2013 5:55 pm
Got looking at my power steering pump now the engine is out and it doesn't bolt up to the 1.3 block, it's a 1992 vitara pump, doesn't look brilliantly simple to bodge either, does anyone know if the Jimny one bolts straight up? If so I'll look for one of them!
timwilks13
Re: power steering
Post by timwilks13 » Sat Nov 23, 2013 11:49 am
No ones tried to use vitara power steering on the 1.3?
Re: power steering
Post by andyrew » Sat Nov 23, 2013 12:36 pm
Hey dude
I think there's something about triming down
A thread mount on the block and re drilling the bracket
Drop Steve green a pm as I think he's done it. Im going to be
Doing It soon ish.
Its the bottom pulley that can be an issue
I bought mine from America
Ladaman
Re: power steering
Post by Ladaman » Sat Nov 23, 2013 12:55 pm
This is the mod I did to mine when fitting it to the 1.3 engine.
Just a little tab welded on, and re-drill a couple of holes. I seem to remember it wasn't running parallel to the crank front to back, so I had to slightly adjust a mounting pad on the engine block to true it up.
It's a bit of a PITA, but just fiddly to get right.
Power steering bracket 2.JPG (2.33 MiB) Viewed 5305 times
Ladaman
Re: power steering
Post by Ladaman » Sat Nov 23, 2013 1:00 pm
Oh yeah, you need to fabricate a wedge too to fit a Vitara steering box (but not for a Jimny one). I'm sure I have details, but cant just find it at the moment. I will find it and put it up later if no one else does, as it's a common file on forums.
timwilks13
Re: power steering
Post by timwilks13 » Sat Nov 23, 2013 3:17 pm
Cheers guys, I have the layout for the wedge that needs making, but i have a different mounting bracket to yours ladaman, I'll have a look later, and throw a picture up I might be missing something important!
trotter
Re: power steering
Post by trotter » Sat Nov 23, 2013 5:15 pm
Check dan_2k's build for power steering info I would link it but I'm on my phone
if in doubt, FLAT OUT!
