Steering Problem
ferris
Steering Problem
Post by ferris » Wed Mar 12, 2014 6:48 pm
Hoping someone might be able to shed some light on a problem im having with my steering. Its been fine up until monday evening now it just seems to have a mind of its own, mainly pulling to the left.
So far i have checked the brakes are not locking on
no play in the wheels, bearing seem fine
Ball joints on the steering bars look fine
Power steering is working
shocks are fine
Tracking is fine
Tyres are at the same pressure
Rag joint had a tear in it so i made a new one but made no difference
Now im stuck and dont know what it could be. The only thing i can think off is maybe the axle is bent.
Re: Steering Problem
Post by Jordi » Wed Mar 12, 2014 7:23 pm
Is it doing it all the time? Under braking? Randomly at any time?
ferris
Post by ferris » Wed Mar 12, 2014 7:34 pm
Its doing it constantly, braking dosent affect it. Its really got me stumped :er:
Post by twiss » Wed Mar 12, 2014 8:35 pm
Have you got a steering damper on there? Can't remember if someone said you don't need one with power steering
Not the most likely candidate but ive heard they can break one way so might be worth checking
Ladaman
Post by Ladaman » Wed Mar 12, 2014 8:59 pm
What's the bushes and bolt tightness at the ends of the springs like?
The bolts on my D flex shackles once came a little loose and it was very scary.
Rhinoman
Post by Rhinoman » Wed Mar 12, 2014 9:53 pm
Busted CV maybe?
Post by ScottieJ » Wed Mar 12, 2014 10:18 pm
Rhinoman wrote:Busted CV maybe?
I was about to suggest this.
ferris
Post by ferris » Thu Mar 13, 2014 10:28 am
Thanks for the replys guys. Iv checked the steering damper and that's fine. The shackles are nice and tight Bush's look good. Haven't checked the cv's yet. Is there a way of testing them without taking the hubs apart?
Post by twiss » Thu Mar 13, 2014 10:33 am
surely if the freewheeling hubs are unlocked the CV wont make a difference apart from when you are actually turning the steering?
I drove around with a busted CV for ages ;)
Ladaman
Post by Ladaman » Thu Mar 13, 2014 10:47 am
Are the U bolts tight?
