Twiss' Samurai 16v
Re: Twiss' Build/Breakages Thread!
Post by twiss » Thu Feb 20, 2014 12:53 am
Just a quick bump and an update
Boxgrove pay and play very successful... still fixing bits on my two mates vitaras though haha
Good testing session though, but MOT is coming up in 3 months so time to think about what to do!
... and other bits too
My list so far:
- Replace rear axle oil seals (arriving tomorrow)... mostly holding but i have to keep refilling the diff haha
- Convert to rear discs... got all the bits, apart from the 2 brake hoses, so will crack on with that tomorrow.... always have to replace rear brakes for MOT and getting fed up with it!
- Fit new window to fastback... not really necessary but the weather will be nice again soon haha
- Make, fit and tune EFI... I have all the engine parts required except for fuel pump+filter, and engine trigger wheel and sensor... ordering my megasquirt this month for sure :)
Might run twin coil packs to I dont have to shell out for coil on plug straight away
I always have to tune my emissions on the tester but I don't like the way it drives afterwards so adjust it back again ;)
- Make wheel arch extensions
- Replace dash with tablet... speedo doesn't work and the MOT man was funny about it last year :P
Post by Anton » Fri Feb 21, 2014 2:29 pm
twiss wrote:Convert to rear discs... got all the bits, apart from the 2 brake hoses
Part number BFH3213 on brakes international, or (better still) go to dave at llama...
Post by twiss » Fri Feb 21, 2014 2:30 pm
Im just going to get the shortest brake hoses I can find... as they dont really need to move, just connect the pipe to the caliper ;)
Post by ScottieJ » Fri Feb 21, 2014 3:44 pm
I just run full length braided flexi's from the T-piece to the calipers.
Post by twiss » Wed Apr 30, 2014 5:41 pm
Just a quick update on my zook:
As I've just snapped my brake drum center in half and won't be coming to billing I've decided to do a virtual lift to make good use of the time!
Chopped out my passenger side rear arch today, going to do the welding tomorrow and will post some pictures up! Considering how rubbish it looks from the inside there's not actually a load of rust underneath the arch mount, so should be quite easy
Post by twiss » Sun Jun 08, 2014 4:14 pm
So virtual lift update, its slow going with my bad knee and limited finances but its getting there!
I started off my cutting out the rust near the seat belt that I knew Mr MOT man would pick up on
Excuse the patchwork quilt effect I am trying to use every last scrap of new metal Ive got in the garage, but theres no hole any more!!! ;)
This is how much of the arch I cut out, done the same on the other side as well now!
Mostly done but with a few odd shaped holes left in it
Curve at the front and rear of the arch
Test fit with an unmodified plastic arch
Proper fit with the trimmed down arch... not bolted up yet so the extension material isn't following the curve properly, or sticking out enough, but you get the idea ;)
Post by donkeychomp » Sun Jun 08, 2014 10:03 pm
Good stuff Twiss!
Ever thought about washing the poor little zook? :D
Post by twiss » Sun Jun 08, 2014 10:34 pm
Nah I just grind the mud off haha
Im going to wash it a bit more before I do any painting
Post by twiss » Mon Jun 23, 2014 6:54 pm
Its update time :)
Passenger side rear arch, quite happy with this one
Driver side rear arch, more rusty and less decent bits of metal... ended up a bit bumpy but looks better than what was there before haha
Passenger exterior flappy bit all glued and bolted down
Drivers exterior showing dodgy hole cut in it for the filler cap to fit past ;)
Jay18
Post by Jay18 » Mon Jun 23, 2014 7:05 pm
Looks good so far mate! Should be able to flex them 31's nicely now :D
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
