Is it really worth the effort putting a Vitara engine in a 413 Samari ??????
Jim
VITARA
Re: VITARA
Yes, definitely!
They are so easy to put in, its ridiculous that they didn't offer a 1.6 Samurai out of the factory!
If your 1.3 goes pop then I would definitely put a 1.6 8v in it.
With an adapter plate the 1.6 will pretty much bolt straight onto the gearbox, without the adapter kit its a few minutes with a drill. Then you have to move the driver side engine mount.
You can either buy a custom mount or just drill a new hole in the existing mount!
I used to be an advocate of not using an adapter plate, but it makes it so easy I think its worth the extra £40 or so
There is a guide here
http://www.suzukiclubuk.co.uk/diy/15-en ... 1-6-engine
Re: VITARA
Defiantly worth it
Re: VITARA
Well worth it!
- timwilks13
- SCUK Website Padawan
Re: VITARA
Nah mate you wanna drop a 4tonne diesel in if you can! JOKES! yea man drop a 1.6 in, as said, rather easy to do, noticeable difference, get swapping!
