Post
by Anton » Tue Oct 21, 2014 9:07 pm
Standard Vitaras have different length left and right driveshafts unless you have done the anvil mod. If you'd done that, then you wouldn't be asking about driveshafts...
But I think that you meant to ask if freewheeling hubs and fixed drive flange hubs are interchangeable. Answer is yes, if that's what you meant to ask.
When offroading, flanges and freewheeling hubs will act exactly the same (that is to say, they'll both keep your front wheels turning) so there's no difference between them offroad.
Fixed hub flanges are a bit stronger, as there's nothing in there to break. But Aisin freewheeling hubs are fitted to much bigger, heavier trucks (same hub, just different driveshaft spline pattern) like the Toyota Hilux, and rarely do they break on those trucks - so they're more than strong enough for Suzuki trucks.
Just don't try fitting a Hilux hub to a zuk.
