Sj power steering conversion
Smarty
Re: Sj power steering conversion
Post by Smarty » Tue Apr 22, 2014 5:59 pm
dan_2k_uk wrote:If you look through my build thread there are some fitting photos of my PAS setup including collapsing the bracket so it clears the radiator mount on the chassis.
Think iv taken on a bit more than I can handle lol all looks a bit complicated to me! :/ not exactly a pro mechanic or fabricator haha
Anyone wanna help!? Haha
Post by dan_2k_uk » Tue Apr 22, 2014 6:14 pm
Its pretty much bolt on but you need to re drill a vitara double bottom pully to fit the 1.3 engine
Smarty
Post by Smarty » Tue Apr 22, 2014 6:16 pm
dan_2k_uk wrote:Its pretty much bolt on but you need to re drill a vitara double bottom pully to fit the 1.3 engine
Ok thanks. Will give it a good go anyway, only way to learn I guess!
Post by ScottieJ » Tue Apr 22, 2014 7:44 pm
Anton wrote:
Having a "wedge" probably counts as a modified steering setup, and I may need to put my SJ through the 8 point system inspection one day - a jimny box, being a direct bolt on replacement, and an OEM part, should mean not losing those points.
You worry too much, it's barely even noticeable and bolt on so it shouldn't make a difference. Why would you need to put it through an 8 point inspection??? Doesn't take much to keep 8 points anyway.
Post by Anton » Wed Apr 23, 2014 2:46 pm
I worry because VOSA/DVLA are full of jobsworths. My axles are not original, my suspension is not original, if I do an engine swap my engine/transmission won't be original - and then I won't have 8 points!
I'll probably be ok, but the less there is to point at and tut over, the happier I'll be that I could have it inspected under the radically altered vehicles scheme and not have to worry.
I may never have it inspected, but if I ever do go coils, I'd probably have to.
Post by ScottieJ » Wed Apr 23, 2014 4:37 pm
Anton wrote:I worry because VOSA/DVLA are full of jobsworths. My axles are not original, my suspension is not original, if I do an engine swap my engine/transmission won't be original - and then I won't have 8 points!
Your axles are original ;) they are still SJ axles. your suspension is original....just because the springs and shocks are aftermarket does not really mean that it will loose the points for those, it's bolt on, they aren't modified.
I think you are reading into it too much :lol:
Damn the way you are saying it my sj should have gone in for an inspection years ago :lol: FUCK THAT! it passes it's MOT every year, the engine is registered on the V5.... I haven't removed any structural crossmembers or mounts from my chassis or modified the chassis rails.....It's still identifiable as an SJ.....All mods are declared on my insurance.....
I'm legal :mrgreen:
