Post
by dan_2k_uk » Fri Aug 08, 2014 2:25 pm
Can tell this is going to be a good one.
Nice truck and great work
With regards to the sagged YJ spring I would just fit it on the passenger side. The drivers side one will soon adjust to match it.
Kiwibrad
Post
by Kiwibrad » Fri Aug 08, 2014 2:32 pm
Cheers Scottie. That's the way they were labeled from the person I bought them off but I thought he had it wrong and that it would be 5 leaf in front and 4 in rear.
ianedwards
- SCUK Addict
Post
by ianedwards » Sun Aug 10, 2014 10:32 pm
Very nice, looking good fella.
Ian.
Kiwibrad
Post
by Kiwibrad » Sat Aug 16, 2014 8:22 am
dan_2k_uk wrote:Can tell this is going to be a good one.
Cheers dan. I hoping its going to be a good one! Its taking me long enough!!! Your probably right about the other spring matching after time! Have had a quote from jones springs to reset.....£65 per spring so think I will send the pair off and get it right to start with.
Kiwibrad
Post
by Kiwibrad » Sun Nov 02, 2014 7:36 pm
- image.jpg (402.25 KiB) Viewed 7980 times
Well it's been a while since I've made much progress,
been busy with work and had a holiday so running way behind where I thought I'd be at this point!! Also been doing little fiddly jobs. Couldn't find a Japanese brake servo when I was looking so I pulled mine apart and modified it to remove the spacer between it and the bulkhead. Didn't take any pics of the inside but I welded 2 more studs inside it as they only have 2 so I had to drill and modify the bulkhead and pedal box and then cut the excess off the push rod and tapped a thread onto it.
I've also repositioned the heater tap. It was just getting a bit tight in original position behind inlet manifold.
- image.jpg (568.13 KiB) Viewed 7980 times
- image.jpg (619.97 KiB) Viewed 7980 times
Kiwibrad
Post
by Kiwibrad » Sun Nov 02, 2014 8:05 pm
- image.jpg (612.36 KiB) Viewed 7975 times
The distributor on the gti engine has been a bit of an issue. I first tried a Mazda 323 distributor cap which probably could have worked but I didn't really like it and it would have been an absolute arse to get off, just no clearance to the bulkhead. I looked at adjusting the bulkhead with a hammer but the heater motor is right at that point and I'd like to keep it operational! Hunted around for an angle drive set up. Found a couple of places that did them but they were mega dear! Sat down with a pen and paper and did loads of measurements and took it to a local machine shop, they took a while but did an awesum job! I then trimmed it up, drilled and tapped some holes and it cost a lot less! Hopefully it all works!
I've also shifted the battery to the left side and made an airbox with a higher intake in the top corner.
Starting the wiring up process now as well.......got a helper for that luckily, my wiring skills are a bit rusty! Hopefully it will fire into life soon
- image.jpg (663.81 KiB) Viewed 7975 times
- image.jpg (505.91 KiB) Viewed 7975 times
- image.jpg (489.65 KiB) Viewed 7975 times
- image.jpg (638.35 KiB) Viewed 7975 times
Ladaman
- Suzuki Guru
Post
by Ladaman » Sun Nov 02, 2014 9:13 pm
Some nice work going on there to get the engine in.
It's a great feeling of satisfaction when your backs to the wall and then a Eureka moment hits and a plan falls into place. Keep up the good work.
- The Boss
Post
by ScottieJ » Sun Nov 02, 2014 10:33 pm
Nice work on the angle drive mod.
Moe over on a few other zuki forums just actually had a batch made as he had the same issues finding them for a decent price, still ended up being around £185 each plus shipping from Norway.
- image.jpg (184.43 KiB) Viewed 7960 times
- image.jpg (59.09 KiB) Viewed 7960 times
https://www.facebook.com/media/set/?set ... 696&type=1
Kiwibrad
Post
by Kiwibrad » Sun Nov 02, 2014 11:21 pm
Ha. Think I got a price of him a while back. His are probably a bit better as his shafts are bigger diameter. I kept mine real simple with a small shaft all the way through and used the bearing from the old dizzy. My thought was although it spins fast there is not a huge load on it. Hopefully it does the trick It came in at £45 so a considerable saving!
robwizard
Post
by robwizard » Fri Nov 21, 2014 10:55 am
Amazing work! Excited to see how this progresses.
