2" lift Kit
percy
Re: 2" lift Kit
Post by percy » Sun Sep 07, 2014 12:30 am
Didnt get that with mine when I did springs and shocks over to ome and it lifted mine from 29 inches to 31 inches so sorry rinoman :armsup:
Keep the shiny side up. ...
Rhinoman
Re: 2" lift Kit
Post by Rhinoman » Sun Sep 07, 2014 1:58 pm
OME struts aren't usually slotted, the holes are drilled in slightly different positions to stock to correct the camber. If you're not getting any scrubbing then they are definitely corrected!
percy
Re: 2" lift Kit
Post by percy » Sun Sep 07, 2014 2:42 pm
Thanks for explaining that as im a newbie to modifying these ( bring back the 80's) think im having a second youth but in an old body
PhilD
Re: 2" lift Kit
Post by PhilD » Thu Sep 18, 2014 9:54 pm
I fitted 1 1/2" strut extensions to keep the full strut movement and 2" list coil spring , I used the camber bolts set to the max and had to turn them right back because it was like turning up hill when I turn the wheel but now they are set like a standard bolt it feels great and the tracking and toe is correct ?
