Hallo guys!
Re: Hallo guys!
Post by Anton » Sun Jan 03, 2016 10:34 pm
:welcome2:
Re: Hallo guys!
Post by ScottieJ » Mon Jan 04, 2016 3:05 am
The easiest way is to just use a 1.3 gearbox. It's a lot of work to fit the vitara gearbox and no cheaper because you need to convert the output of the gearbox to bolt up to the transfer box with a shortened propshaft. As Robbie says the transmission tunnel does also need a few tweaks but it won't be as extensive as mine unless you choose to spend a lot of money on a twin transfer box set up.
Terrierman
Re: Hallo guys!
Post by Terrierman » Mon Jan 04, 2016 9:49 am
Thanks a lot!
Ok! I get it!
Engine swap will be my last work. At the time i almost finished with electric problems and i started bodywork. :weld:
Re: Hallo guys!
Post by dan_2k_uk » Mon Jan 04, 2016 5:27 pm
Hi and welcome.
Just try it with the 410 engine and enjoy it. As long as your tyres aren't too big you can go have some fun.
Terrierman
Re: Hallo guys!
Post by Terrierman » Thu Jan 07, 2016 2:43 pm
Dan that i 'm going to do until to finish suspension and body works! ;)
Re: Hallo guys!
Post by Anton » Fri Jan 08, 2016 12:30 am
Pix of the wee beastie! We need pictures!
Terrierman
Re: Hallo guys!
Post by Terrierman » Thu Jan 14, 2016 8:26 am
This is from my first ride at the mountains
Re: Hallo guys!
Post by Anton » Thu Jan 14, 2016 8:26 pm
:rockin:
Re: Hallo guys!
Post by Tramp » Thu Jan 14, 2016 9:53 pm
Great photo - living the dream!
