Mine was having such a job drawing power to the solenoid that the ignition barrel internals have now melted! So now the ACC terminal is internally connected to the starter terminal!
Time for a starter button I think!
starter motor problem
Re: starter motor problem
- turbo-tom
Remember to get a decent one ive got a graystone one now and thats really good!twiss wrote:Time for a starter button I think!
Yeah don't really need that much of a decent one as its only powering up a relay now...
I've seen this exact problem with a Lada Niva. Basically Twiss's right (if your problem is the same thing) - with the Niva, basically the cable that carries power to the starter just got frayed internally over time and lost it's ability to carry a decent current - the starter couldn't pull enough amps from a perfectly decent battery, and acted like it wasn't getting power.
The solenoid, only needing a fraction of the power, engaged just fine.
We ran a new cable and it worked just fine.
So try running a separate cable directly from the battery to terminal A on Darrel's diagram, turn the key and see if the problem goes away. If it does, replace the cable that goes to A, or run a new one through a relay as everyone's suggesting. Don't forget to add an inline fuse to the new cable though, it's a real fire hazard to have something unfused connected directly to your battery!
If it doesn't, that means something in your starter (between A and C) is b0rked. Open up your starter and look for damage.
- ScottDabinett
I went off roading sunday stopped and turned it back on and it was fine and has been fine today!! Weird!!
Thanks for all your help though!
Bit of a shake around probably moved some mud around in there
