Page 3 of 5
Re: the monster
Posted: Mon Jan 25, 2016 10:36 pm
by genders
so time for a update......
ive decided to use the sj axles as it is less fabrication and ive got enough to do as it is. here are the axles being preped for paint. ive also just been given some brackets for a rear disk conversion. im 1 brake disk and some wheel studs short, hopefully my buddy is droping me some over this week
axles on chassis, body not bolted down yet because i need to weld up new engine mounts ect.
front bearings are shot. time to save some pennys for a full set
Re: the monster
Posted: Tue Jan 26, 2016 9:52 pm
by genders
flipped and painted rims
engine before rebuild
engine stripped down to block, painted, cavalier sump fitted so the pick up is at the rear and doesnt get smashed by axles
head stripped and cleaned, injectors cleaned. i have a full new set of seals and gaskets to go on the engine
Re: the monster
Posted: Wed Jan 27, 2016 10:19 am
by Martin86
Great Work!
Re: the monster
Posted: Wed Jan 27, 2016 12:43 pm
by ektoz
looking good man!
Re: the monster
Posted: Thu Jan 28, 2016 9:29 pm
by genders
Vaulves re seated, new stem seals. The head is now back on the engine but my camera battery ran out of Juce. There's a few bits I want to check before I mess about putting the engine in, if all goes well I'm hoping to drop it in this weekend
Re: the monster
Posted: Sat Jan 30, 2016 6:29 pm
by genders
so some progress.....
engine 95% back together,
transer box bolted up, this will need to come back out when i get round to making a cradle for it and stronger mounts
ive started to line up the engine , so far ive done the gearbox mount (carlton mount with some new holes) the other mounts will take a little more time and i was getting a bit fustrated with it today so i decied it was time to down tools and continue in the morning
Re: the monster
Posted: Sun Jan 31, 2016 7:50 pm
by genders
so engine is in... i used the carlton mounts with landrover heavy duty rubber bits and custom made the chassis mounts out of sheet steel, it was a pain trying to get the prop to line up but i think ive got pretty much in line now
also noticed with the spring over axle conversion the prop may need to be a bit longer.
Re: the monster
Posted: Mon Feb 01, 2016 10:23 am
by genders
So ive worked out I've welded the mounts in wrong so ive got to shorten them a bit and move it forward a bit. Should get this done tonight
Re: the monster
Posted: Mon Feb 01, 2016 11:23 pm
by Anton
If you're gonna do it, do it right right.
Re: the monster
Posted: Tue Feb 02, 2016 11:51 am
That engine does look like its sitting pretty high, you want to mount the engine and trans so that it slants back slightly, keeping the angle of the gearbox output parallel to the Tbox input or you might experience vibrations at speed.
