kibris
Post
by kibris » Thu Apr 25, 2013 9:03 am
ektoz wrote:No problem mate i also really enjoy our chat, see you again very soon!
lets hope my 4 front CJ's will come in time to start working on it,
Hi Ektoz - i did the CJ fronts on the rear, then rears up front - its world of difference mate, well worth doing.
Cyprus Geoff
- Can I have a tow
Post
by Cyprus Geoff » Thu Apr 25, 2013 9:10 am
Yeah and they must be REALLY strong springs
How many springs did you end up using Mark, just the standard packs or did you play around removing springs at all?
kibris
Post
by kibris » Thu Apr 25, 2013 10:34 am
yeah Geoff stick to the day job mate
I did play around with the spring packs - swapped a couple of leaves around - to be honest cant 100% remember just what I did - took a couple of attempts to get everything just as i wanted it as I recall - nothing major!
ektoz
Post
by ektoz » Thu Apr 25, 2013 10:57 am
they say that i will need 4 front and 5 back, can you check when you can Mark?
kibris
Post
by kibris » Fri Apr 26, 2013 9:30 am
Its the other way round i removed the 2 bottom leaves on the CJ's (the ones the bend the other way) then took off one of the leaves and I think I put that on the Front (rears up front) so I have 5 on the front (engine weight) and 4 on the back - as I said i did swap l;eaves about a bit with others I had - so not 100%
ektoz
Post
by ektoz » Fri Apr 26, 2013 8:15 pm
Thanks buddy, got them today i will start working on monday
sam16v
Post
by sam16v » Sun Apr 28, 2013 5:20 pm
Im running the C.J fronts on the rear and Rears up front.
Have made my own missing links for the front, to sort the extra length. Relocation plates and missing links for the back, at the moment the shocks are limiting the travel, so got to build some shock towers, and get even longer brake-lines again! however already the ride is 100% better and seems to flex well.
ektoz
Post
by ektoz » Sat May 11, 2013 7:21 pm
fronts are on with toyota RAV4 shocks
Post
by Anton » Sat May 11, 2013 8:32 pm
Nice work!
Liking the look of that. Has anyone mentioned anything about PTFE/grease between the leafs (leaves?)? I know you've spoken with Geoff in person, so I don't want to go over things you've already talked about.
Post
by dan_2k_uk » Sat May 11, 2013 11:07 pm
Is that a fibreglass body? Nice fast work!
