Page 3 of 4
Re: My new build
Posted: Fri Jul 19, 2013 2:01 pm
by Pascal
So now few changes, bigger winch! But now we must redo front to fit it properly. here is the work!
Hu weld on the front.jpg (120.33 KiB) Viewed 8359 times
Hu weld on the front 2.jpg (137.07 KiB) Viewed 8359 times
TIG detail.jpg (1.19 MiB) Viewed 8359 times
My guys fitting the original bumper.jpg (127.82 KiB) Viewed 8359 times
Re: My new build
Posted: Sat Jul 20, 2013 2:36 pm
by Pascal
And finally is done! Mounted under the STD front bumper, tested, winched all days with it, put under the mud and so on.... Now sure i do will hang it from the roof of my factory! Will send you pictures! :smokin: :smokin:
Preping before pain job.jpg (141.69 KiB) Viewed 8350 times
And its painted.jpg (33.56 KiB) Viewed 8350 times
And all this fits under the STD front bumper.jpg (33.8 KiB) Viewed 8350 times
Mounting and wiring winch before the bumper mounting.jpg (106.35 KiB) Viewed 8350 times
From next week we start to work on new lift kit, 80mm plus brake system. (Final lift will be over 120mm!! This 80 mm is just development for guys that want it later!) At moment driving with 40 something (like 2 inch for imperial guys) and its flawless! Even at MAX speed (Around 150 KM/H) have no issues whatsoever. Taken even to the race track!! Installation is super easy and no other changes needed. Now for 80mm sure will be needed brake lines, relocation brackets to make it perfect, better sway bar (Anti rolling bar) to make it sitll capable on the roads and so on. Will see! Will keep you posted.
Uncle Pascal
Re: My new build
Posted: Sat Jul 20, 2013 2:57 pm
by Edweird
With the standard grill and bumper off, the Jimny looks a lot less cute and girly compared to normal. The bumper's easy enough to have an alternative one fabricated but a custom grill would be more difficult to make something that looks good.
Re: My new build
Posted: Wed Jul 31, 2013 7:00 am
by Pascal
And here it is how looks at moment!
Now next steps, carbon fiber LED-Si roof lights! (Can work over 4 days just on battery!!), Super lightweight, massive lumen delivery, customized and possibel to have in few different sizes!
Then new engine setup, 1.6 bore, titanium coated side skirts, ceramic coated top lightewight foged pistons, Arrow Precision H-Beam connectin rods, Longer duration cams. All this to deliver more TORQUE, not really horse power. Target is on 950RPM to climb wihout having need to put accelerator! Means go over 40 degrees only on idle engine speed.
And last but not least solar panels and second electrcal system self sufficient for cooking, Air-Conditioner, refrigerator, plasma TV, PC and some LED-Si lights. ^_^
Considering tht is ALL done in the house, sure will need a week at least! So please look for updates in some week time. ^_^
My Jimny at moment.jpg (267.38 KiB) Viewed 8315 times
Re: My new build
Posted: Wed Jul 31, 2013 11:14 am
by dan_2k_uk
That winch looks brilliant poking through the bumper!
Re: My new build
Posted: Wed Jul 31, 2013 2:21 pm
by Edweird
This is a great build to watch. :D
Re: My new build
Posted: Wed Jul 31, 2013 2:24 pm
by turbo-tom
looks good. shame the tyre's let it down.
Re: My new build
Posted: Wed Jul 31, 2013 2:27 pm
by Edweird
turbo-tom wrote:looks good. shame the tyre's let it down.
Given the lift and spacers, I bet there's some wheels and tyres incoming.
Re: My new build
Posted: Wed Jul 31, 2013 3:47 pm
by windsor
Looking good
Re: My new build
Posted: Tue Aug 06, 2013 6:04 pm
by Pascal
Tires are soon in! Just a bit busy lately with my work. Sorry guys! ^_^
