My new build
Pascal
My new build
Post by Pascal » Mon Jul 15, 2013 1:27 am
Is it okay if i post here what i am doing to my poor Jimny? Just purchase brand new Jimny and will kill it! heh I hope is okay here.
Re: My new build
Post by dan_2k_uk » Mon Jul 15, 2013 9:17 am
Hi and welcome to SCUK
Yes this is the correct section for a Jimny build.
Would love to see some photos. What are your plans for it?
The Zee
Re: My new build
Post by The Zee » Mon Jul 15, 2013 4:26 pm
I also have a new Jimny. Would be great to hear what you are going to do. Might give me some ideas.
Are you going to make it an animal or a pavement princess?
Pascal
Re: My new build
Post by Pascal » Mon Jul 15, 2013 4:55 pm
Okay! So here we go! First things first, means suspension lift 40mm, body lift 50mm. All mounted and done in the house. (we fill 43TX oil in shocks!) So they dont overheat. Valving I order from Ohlins or maybe TEIN.
Body lift 50mm.jpg (98.66 KiB) Viewed 10187 times
Joe with mech.jpg (84.59 KiB) Viewed 10187 times
Soon will post our new wheel spacer! 60mm! Means 12 CM wider track!
Pascal
Re: My new build
Post by Pascal » Mon Jul 15, 2013 5:01 pm
And here is wheel spacers. Made of AL 7075T6, available in various colors!
60mm spacer with PRo lug nuts.jpg (32.83 KiB) Viewed 10185 times
(And pay attanetion on those loooong lug nuts!) They are lightweight, very strong, easy-to use in deep mud! They come in 11 different colors! (My favour one is Brown Titanium!)
ASR Lug nuts.jpg (33.72 KiB) Viewed 10185 times
ASR Lug nuts 2.jpg (34.3 KiB) Viewed 10185 times
Also thread protection caps are available too! Protect your wheel studs from dust, mud and all other heavy stuff that enters into your lug nuts!
Re: My new build
Post by Edweird » Mon Jul 15, 2013 5:05 pm
This looks like it's going to be a fun build to watch.
Re: My new build
Post by Jordi » Mon Jul 15, 2013 5:36 pm
Hmmm, 60mm spacers. Thats a big old spacer. Are you not concerned about the stress on the original wheel studs or the bearings?
Sounds like you have some pretty serious plans for it.
Re: My new build
Post by turbo-tom » Mon Jul 15, 2013 9:24 pm
looks good but good bye wheel bearings.
Pascal
Re: My new build
Post by Pascal » Tue Jul 16, 2013 1:44 am
As for OEM studs, i did make new once. As for bearings, have already 2 sets of spare once! :brows: :brows:
But honestly, when arrive my tires, then will decide which road to go. Now these days puting much higher lift, my guys finished new shocks, so soon will lift higher. When I do my brakes lines (For over 2 inch needed brakes lines!) then will install it. Body is cool to lift wihout touching like 50mm. Now will see what is needed to lift 150mm! (Its around almost 6 inch) Just a bit worried about that could roll over in some situation? Anyone ever rolled over one Jimny?
P.S. You must forgive me for my English.
Pascal
Re: My new build
Post by Pascal » Tue Jul 16, 2013 1:53 am
Just preped my new recovery set! Coolest thing is that cost almost like 5 icecreams! (Means almost nothing!) :D :lol:
Safety easy-hook.jpg (24.15 KiB) Viewed 10150 times
Recovery Set.jpg (20.39 KiB) Viewed 10150 times
Hooked Up.jpg (137.95 KiB) Viewed 10150 times
Coming soon new winch! Sure cant wait for it!! Will go nice with this recovery set!
