overheating on 1.7td engine conversion
Re: overheating on 1.7td engine conversion
mine overheated like mad then finally got a hole in so decided to go with the 200tdi i've fitted it today just got to pipe it up. just have no idea where to put my turbo cooler as it does not fit at the side of the radiator. just looking for a solution
Eat! Sleep! Offroad! Fix! Repeat!
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
- Edweird
I'd mount the intercooler behind the rad, or possibly move the number plate and cut a hole in the bumper, or you could just not have it in at all.
It cools the air going into the engine so you get a little more power. You can do without it.
no chance of sitting behind the rad and ive got 2 electric fans cooling the 200tdi rad at the front. argh i just wanna get offroad lol. you can do without it? surely it wouldnt be there if you did not need it?
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
- Edweird
As I said, intercoolers cool the air going through them. Cooler air is more dense so when you heat it up (i.e. when the engine fires) it expands more, forcing the piston down harder.
If you do away with it you'll just not get the same peak power. In an offroader intercoolers don't help much anyway because you're not moving very fast. A cold air intake would serve you better.
how would i go about the cold air intake? sounds promising
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
- Edweird
Having had a closer look at your avatar photo, your snorkel does half the job of a cold air intake. It's taking air from outside the engine bay. Under the bonnet you want to keep the ducting as short as possible and away from hot areas, like the exhaust, as much as possible.
just like to say I cured all over heating problems
200tdi rad did the job for me with digital thermostat. the cooler fitter behind the passenger side front light with a scoop
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
nice work
- Edweird
Sounds great. Any chance of a couple of photos?
yeah ill get a few photos up tomorrow cheers for all support guys
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
