overheating on 1.7td engine conversion
Shawboy
Post by Shawboy » Mon Oct 07, 2013 3:02 pm
anyone else had this problem?
Eat! Sleep! Offroad! Fix! Repeat!
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Re: overheating on 1.7td engine conversion
Post by dan_2k_uk » Mon Oct 07, 2013 3:20 pm
What rad are you running?
Shawboy
Post by Shawboy » Mon Oct 07, 2013 3:28 pm
its not the rad as i changed it for the 1.7td astra rad . im now thinking its the temperature stat giving of a wrong signal to the temperature gauge.
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by Jordi » Mon Oct 07, 2013 5:56 pm
If your running the 1.7 temp sender and the 1.3 temp gauge they won't be calibrated together, giving a false reading.
Shawboy
Post by Shawboy » Mon Oct 07, 2013 6:29 pm
ive ordered a digital one so should sort that problem out. Im fitting it along with a 200tdi rad
or would you leave the 1.6 vitara rad in??
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by Jordi » Mon Oct 07, 2013 6:39 pm
As long as the rad is the correct rad for the engine and the fan is located correctly behind it i wouldn't change it again.
Just try a different / universal temp gauge
Shawboy
Post by Shawboy » Mon Oct 07, 2013 6:48 pm
yeah i will get the gauge fitted see how it runs if not i got 2 option either t it off to the back and fit a spare rad and fan or change the one in it as i think the 200tdi is the largest one you can fi in the front.
ive just took the power steering pump out and instead of 2 belts am running on 1 now with my alternator sounds and runs sweet like this.
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by Jordi » Mon Oct 07, 2013 7:11 pm
Why not just fit power steering?
Shawboy
Post by Shawboy » Mon Oct 07, 2013 7:45 pm
personal opinion i prefer no power steering offroad you get a better feel!
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by turbo-tom » Mon Oct 07, 2013 8:21 pm
Shawboy wrote:personal opinion i prefer no power steering offroad you get a better feel!
I always thought that. By boy I could go without it now! :D
